  • 1 Vote(s) - 5 Average
mute philco 19 or 89 or all between
OK!
I'll take a small break and replace those, that will at least keep me going in something I already know.
Also! The values of the cps are......25,.09,.09,.05,.05
seeing as .09 are unavailable I plan to use .1's in their place.
Agreeable?
One more thing I'm harping about is the 2nd IF Transformer.....there are two lugs that show continuity...that's the one I fixed. Shouldn't the last two lugs also show continuity unless there's a break somewhere in the winding?
RE: mute philco 19 or 89 or all between - by confused1 - 08-26-2014, 09:56 PM
RE: mute philco 19 or 89 or all between - by confused2 - 08-29-2014, 09:37 AM
RE: mute philco 19 or 89 or all between - by confused2 - 08-29-2014, 09:51 AM
Users browsing this thread: 13 Guest(s)
There are currently 10268 online users. [Complete List]
» 3 Member(s) | 10265 Guest(s)
