Philco PT6
success! works like a charm... Icon_clap
I ended up using the 6.8 volt 5 watt. the 9.1 clamped @ 9.2 but the spike from turning it off and back on quickly was still blowing the bulb. that was my second concern.
just out of curiosity, for the rapid off-on test. I tried a modern 47 (AML from pinball life) and an NOS Tung-Sol 47. The AML blew @ 9.2 and the Tung-sol did not.
I did suspect part of the problem here were the cheap, modern bulbs.
Also.. No 35Z3's were destroyed in this test... Icon_wink
I did test voltages on the tubes as well and all filament voltages are where they should be.
Thanks Again, Mondial
Philco PT6 - by bfrohwein - 08-24-2014, 04:05 PM
RE: Philco PT6 - by morzh - 08-24-2014, 10:41 PM
RE: Philco PT6 - by Mondial - 08-24-2014, 11:08 PM
RE: Philco PT6 - by bfrohwein - 08-24-2014, 11:28 PM
RE: Philco PT6 - by Mondial - 08-24-2014, 11:42 PM
RE: Philco PT6 - by Arran - 08-25-2014, 12:52 AM
RE: Philco PT6 - by bfrohwein - 08-25-2014, 02:18 AM
RE: Philco PT6 - by bfrohwein - 08-26-2014, 10:28 PM
RE: Philco PT6 - by bfrohwein - 09-01-2014, 12:39 PM
There are currently 10035 online users. [Complete List]
» 2 Member(s) | 10033 Guest(s)
