  • 1 Vote(s) - 5 Average
mute philco 19 or 89 or all between
Sounds like you got into the same situation I did just a few weeks ago; i.e. working on a radio that had at least 10 changes during its production run. Good luck.
RE: mute philco 19 or 89 or all between - by Art Hoch - 08-27-2014, 08:41 PM
RE: mute philco 19 or 89 or all between - by confused2 - 08-29-2014, 09:37 AM
RE: mute philco 19 or 89 or all between - by confused2 - 08-29-2014, 09:51 AM
There are currently 9307 online users. [Complete List]
» 3 Member(s) | 9304 Guest(s)
