  • 1 Vote(s) - 5 Average
Second 70 Cabinet Finished
#43
The front panel
[Image: https://farm5.staticflickr.com/4384/3722...429a_z.jpg]105_0966 by Steve Davis, on Flickr
The front panel has been veneered.
I have sealed and grain filled the front panel blank before cutting it out. It is much easier to fill and sand a solid sheet. This picture was taken before wiping the filler off.
[Image: https://farm5.staticflickr.com/4388/3741...8eaa_z.jpg]105_0969 by Steve Davis, on Flickr
I have attached the panel to the pattern and drilled the starter holes.
[Image: https://farm5.staticflickr.com/4486/3724...9670_z.jpg]105_0970 by Steve Davis, on Flickr
[Image: https://farm5.staticflickr.com/4473/3724...bf57_z.jpg]105_0971 by Steve Davis, on Flickr
Cutting out the panel with a pattern bit in a router table.
[Image: https://farm5.staticflickr.com/4362/3701...daf3_z.jpg]105_0964 by Steve Davis, on Flickr
[Image: https://farm5.staticflickr.com/4509/3727...91dd_z.jpg]105_0965 by Steve Davis, on Flickr
Using a Dremel tool with a modified router attachment to chamfer the speaker cutout. I ha ve re-ground an original Dremal router bit to match the profile Philco used.
[Image: https://farm5.staticflickr.com/4441/3727...3818_z.jpg]105_0974 by Steve Davis, on Flickr
Drilling and counter boring the shaft holes.
M R Radios   C M Tubes
Second 70 Cabinet Finished - by Steve Davis - 08-13-2014, 10:06 PM
RE: Second 70 Cabinet - by morzh - 08-13-2014, 10:30 PM
RE: Second 70 Cabinet - by klondike98 - 08-14-2014, 10:03 AM
RE: Second 70 Cabinet - by morzh - 08-14-2014, 11:20 AM
RE: Second 70 Cabinet - by jerryhawthorne - 08-14-2014, 03:20 PM
RE: Second 70 Cabinet - by Steve Davis - 08-15-2014, 07:12 PM
RE: Second 70 Cabinet - by Arran - 08-15-2014, 11:45 PM
RE: Second 70 Cabinet - by tab10672 - 08-16-2014, 01:23 PM
RE: Second 70 Cabinet - by Steve Davis - 08-16-2014, 08:38 PM
RE: Second 70 Cabinet - by jerryhawthorne - 08-16-2014, 08:54 PM
RE: Second 70 Cabinet - by Steve Davis - 08-16-2014, 09:12 PM
RE: Second 70 Cabinet - by tab10672 - 08-16-2014, 09:22 PM
RE: Second 70 Cabinet - by tab10672 - 08-16-2014, 09:25 PM
RE: Second 70 Cabinet - by jerryhawthorne - 08-16-2014, 11:15 PM
RE: Second 70 Cabinet - by tab10672 - 08-16-2014, 11:52 PM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 08:49 AM
RE: Second 70 Cabinet - by OldRestorer - 08-17-2014, 11:11 AM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 11:54 AM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 03:33 PM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 03:50 PM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 04:21 PM
RE: Second 70 Cabinet - by tab10672 - 08-17-2014, 04:36 PM
RE: Second 70 Cabinet - by jerryhawthorne - 08-17-2014, 04:36 PM
RE: Second 70 Cabinet - by Steve Davis - 08-17-2014, 04:46 PM
RE: Second 70 Cabinet - by tab10672 - 08-17-2014, 05:05 PM
RE: Second 70 Cabinet - by Steve Davis - 08-18-2014, 07:56 PM
RE: Second 70 Cabinet - by OldRestorer - 08-19-2014, 01:45 PM
RE: Second 70 Cabinet - by Steve Davis - 08-19-2014, 04:55 PM
RE: Second 70 Cabinet - by morzh - 08-19-2014, 04:55 PM
RE: Second 70 Cabinet - by Steve Davis - 08-23-2014, 08:49 PM
RE: Second 70 Cabinet - by OldRestorer - 08-24-2014, 12:16 PM
RE: Second 70 Cabinet - by Steve Davis - 08-24-2014, 07:33 PM
RE: Second 70 Cabinet - by Ron Ramirez - 08-24-2014, 08:35 PM
RE: Second 70 Cabinet - by Steve Davis - 08-25-2014, 09:31 AM
RE: Second 70 Cabinet - by Chuck Schwark - 08-25-2014, 10:22 AM
RE: Second 70 Cabinet - by Steve Davis - 08-25-2014, 10:03 PM
RE: Second 70 Cabinet - by Chuck Schwark - 08-26-2014, 09:47 AM
RE: Second 70 Cabinet - by Steve Davis - 08-26-2014, 09:51 AM
RE: Second 70 Cabinet - by Pillo69 - 08-26-2014, 09:58 AM
RE: Second 70 Cabinet - by Steve Davis - 08-26-2014, 10:32 AM
RE: Second 70 Cabinet - by Steve Davis - 08-26-2014, 08:39 PM
RE: Second 70 Cabinet - by Steve Davis - 08-27-2014, 08:12 PM
RE: Second 70 Cabinet - by Steve Davis - 08-27-2014, 09:47 PM
RE: Second 70 Cabinet - by Steve Davis - 09-04-2014, 11:34 AM
RE: Second 70 Cabinet - by OldRestorer - 09-04-2014, 01:09 PM
RE: Second 70 Cabinet - by Steve Davis - 09-06-2014, 09:31 PM
RE: Second 70 Cabinet - by PhilcoJohn - 09-07-2014, 05:24 PM
RE: Second 70 Cabinet - by Steve Davis - 09-07-2014, 07:43 PM
RE: Second 70 Cabinet - by morzh - 09-07-2014, 08:16 PM
RE: Second 70 Cabinet - by Warren - 09-07-2014, 11:06 PM
RE: Second 70 Cabinet - by Arran - 09-08-2014, 12:44 AM
RE: Second 70 Cabinet - by OldRestorer - 09-08-2014, 07:50 AM
RE: Second 70 Cabinet Finished - by morzh - 09-08-2014, 08:39 AM
RE: Second 70 Cabinet Finished - by Eric T - 09-08-2014, 08:53 AM
RE: Second 70 Cabinet Finished - by Eliot Ness - 09-08-2014, 09:05 AM
RE: Second 70 Cabinet Finished - by morzh - 09-08-2014, 09:48 AM
RE: Second 70 Cabinet Finished - by OldRestorer - 09-08-2014, 10:04 AM
RE: Second 70 Cabinet Finished - by Chuck Schwark - 09-08-2014, 10:31 AM
RE: Second 70 Cabinet Finished - by Steve Davis - 09-08-2014, 12:41 PM
RE: Second 70 Cabinet Finished - by OldRestorer - 09-08-2014, 03:52 PM
RE: Second 70 Cabinet Finished - by Steve Davis - 09-08-2014, 04:20 PM
RE: Second 70 Cabinet Finished - by OldRestorer - 09-08-2014, 06:54 PM
RE: Second 70 Cabinet Finished - by morzh - 09-08-2014, 07:13 PM
