Philco Model 89 ( Code 123 )
Chuck Schwark's Philco repair bench has some info on them.
http://www.philcorepairbench.com/bblokcap.htm
Philco Model 89 ( Code 123 ) - by NV3G - 10-06-2008, 05:11 PM
Re: Philco Model 89 ( Code 123 ) - by calmark - 10-06-2008, 06:20 PM
Re: Philco Model 89 ( Code 123 ) - by exray - 10-07-2008, 07:14 AM
Eico 232 VTVM Schematic
There are currently 9720 online users. [Complete List]
» 1 Member(s) | 9719 Guest(s)
