Philco 42-1010 Dial Stringing
All right. I went out to the garage, and looked over my 42-1010 chassis carefully. Then I came back inside and looked through the Philco 1942 RMS Year Book and found that, while the dial cord stringing diagram is not given for Models 42-1010 and 42-1011, it IS given for Models 42-1012 and 42-1013.
Good news...the dial cord diagram for the 1012 & 1013 is the same as what you need for your 1010.
Here it is...
[Image: http://i326.photobucket.com/albums/k420/...alcord.jpg]
Philco 42-1010 Dial Stringing - by Jon Scaptura - 12-12-2005, 07:38 PM
[No subject] - by Terry Judkins - 12-13-2005, 12:24 AM
[No subject] - by Chuck Schwark - 12-13-2005, 09:55 AM
[No subject] - by Jon Scaptura - 12-13-2005, 10:23 AM
[No subject] - by Chuck Schwark - 12-13-2005, 11:58 AM
[No subject] - by Ron Ramirez - 12-13-2005, 01:30 PM
[No subject] - by Jon Scaptura - 12-13-2005, 04:45 PM
[No subject] - by Ron Ramirez - 12-13-2005, 05:58 PM
[No subject] - by Ron Ramirez - 12-13-2005, 06:53 PM
[No subject] - by Chuck Schwark - 12-13-2005, 08:16 PM
Thanks - by Jon Scaptura - 12-13-2005, 11:36 PM
Eico 232 VTVM Schematic
There are currently 8971 online users. [Complete List]
» 1 Member(s) | 8970 Guest(s)
