Craigslist GE E-81
Last winter I picked up a GE E-81. I recapped it and did the cabinet
and I added a phono input. it turned out nice and sounded very good with a rich tone. Here are some photos.
Craigslist GE E-81 - by Groundhog74 - 08-27-2014, 06:26 PM
RE: Craigslist GE E-81 - by OldRestorer - 08-27-2014, 06:56 PM
RE: Craigslist GE E-81 - by Groundhog74 - 08-27-2014, 08:33 PM
RE: Craigslist GE E-81 - by Arran - 08-27-2014, 11:47 PM
RE: Craigslist GE E-81 - by morzh - 08-28-2014, 10:05 AM
RE: Craigslist GE E-81 - by Dan Walker - 08-28-2014, 07:15 PM
RE: Craigslist GE E-81 - by Arran - 08-28-2014, 11:40 PM
There are currently 5907 online users. [Complete List]
» 1 Member(s) | 5906 Guest(s)
