Oscillator 06620 repair?
I am working on a Philco 89 ( Code 123 ). The Oscillator is not working. I removed Oscillator Coil 06620 and found the winding between pins 1 and 2 open. Pin 1 goes to the cathode of the Detector / Oscillator tube ( 77).
I removed the coil. I can not see any windings. Please tell me how I go about repairing this coil?
All suggestions are appreciated.
nv3g
Oscillator 06620 repair? - by NV3G - 10-07-2008, 03:06 PM
Re: Oscillator 06620 repair? - by NV3G - 10-08-2008, 05:04 PM
Re: Oscillator 06620 repair? - by Ron Ramirez - 10-08-2008, 05:30 PM
Re: Oscillator 06620 repair? - by mandh - 10-09-2008, 08:38 AM
Re: Oscillator 06620 repair? - by Ron Ramirez - 10-14-2008, 06:49 PM
Re: Oscillator 06620 repair? - by NV3G - 10-21-2008, 07:46 PM
There are currently 7032 online users. [Complete List]
» 1 Member(s) | 7031 Guest(s)
