Philco 77 hacked?
Thanks, Ron. That only leaves the mystery of what ties to lug 3, then. I have much to do on this set, so I have plenty of other work to start in on while I ponder why R18 is across C28 lugs 1 & 3 with 3 seeming to go no where. UPDATE: I found it when I pulled C14. It goes from one of the lugs on C11 directly to lug 3 of C28.
I'm kind of loving this set so far. I think I must be a TRF guy at heart. Oh, a quick Philco question: The large dog-bone resistors (100K, 500K, etc.) are all 1 watt, correct? If Philco need a higher watt rating, they used wire-wound as I understand? Using Chuck's resistor pictures as a guide, they all seem to be in the inch and a half range, so that would be 1 watt, I think?
Charlie in San Antonio
Philco 77 hacked? - by ccomer1955 - 08-06-2014, 08:02 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 12:15 PM
RE: Philco 77 hacked? - by morzh - 08-07-2014, 01:15 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 03:29 PM
RE: Philco 77 hacked? - by morzh - 08-07-2014, 03:38 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 04:36 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-07-2014, 04:37 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 05:44 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-07-2014, 05:47 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 09:07 PM
RE: Philco 77 hacked? - by morzh - 08-07-2014, 10:54 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-07-2014, 11:42 PM
RE: Philco 77 hacked? - by Arran - 08-08-2014, 03:02 AM
RE: Philco 77 hacked? - by morzh - 08-08-2014, 09:30 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-08-2014, 11:12 AM
RE: Philco 77 hacked? - by Paul Philco322 - 08-08-2014, 12:43 PM
RE: Philco 77 hacked? - by morzh - 08-08-2014, 12:56 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-08-2014, 09:52 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-12-2014, 03:07 PM
RE: Philco 77 hacked? - by morzh - 08-12-2014, 03:38 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-12-2014, 10:05 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-23-2014, 03:04 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-24-2014, 08:04 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-24-2014, 10:35 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-25-2014, 01:28 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-28-2014, 11:56 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-29-2014, 05:31 AM
RE: Philco 77 hacked? - by ccomer1955 - 08-29-2014, 12:31 PM
RE: Philco 77 hacked? - by Ron Ramirez - 08-29-2014, 05:39 PM
RE: Philco 77 hacked? - by ccomer1955 - 08-29-2014, 06:17 PM
RE: Philco 77 hacked? - by ccomer1955 - 09-01-2014, 11:54 AM
RE: Philco 77 hacked? - by ccomer1955 - 09-15-2014, 02:08 PM
RE: Philco 77 hacked? - by OZ4 - 09-16-2014, 01:41 PM
RE: Philco 77 hacked? - by ccomer1955 - 09-16-2014, 05:34 PM
There are currently 5418 online users. [Complete List]
» 1 Member(s) | 5417 Guest(s)
