A pair of Radiola 33's
It seems the Radiola 33 can be a common set around here, but most are also trashed when you find them. Metal radios didn't see a lot of love around my area as the woman of the house usually did not like them at all!
A pair of Radiola 33's - by Jayce - 08-29-2014, 02:03 PM
RE: A pair of Radiola 33's - by OldRestorer - 08-29-2014, 05:06 PM
RE: A pair of Radiola 33's - by Jayce - 08-29-2014, 09:54 PM
RE: A pair of Radiola 33's - by Arran - 08-31-2014, 12:48 PM
There are currently 6022 online users. [Complete List]
» 1 Member(s) | 6021 Guest(s)
