Bakelite blocks
This brings up a good question about the working voltage on the .0001 uf (Silver Mica replacements). The universal bakelite block description states 1200V! Do they need to be rated that high? It seems higher rated ones aren't easy to come by. Is 1000V enough, or 500/600V?
Bakelite blocks - by Guest - 10-08-2008, 03:09 AM
Re: Bakelite blocks - by Doug K. - 10-08-2008, 06:35 AM
Re: Bakelite blocks - by Chuck Schwark - 10-08-2008, 09:30 AM
Re: Bakelite blocks - by Guest - 10-08-2008, 03:35 PM
Re: Bakelite blocks - by Ron Ramirez - 10-08-2008, 05:27 PM
Re: Bakelite blocks - by Chuck Schwark - 10-08-2008, 09:34 PM
Re: Bakelite blocks - by Guest - 10-08-2008, 10:56 PM
Re: Bakelite blocks - by mandh - 10-09-2008, 08:34 AM
Re: Bakelite blocks - by Chuck Schwark - 10-09-2008, 09:33 AM
91H Code 126 Restore
