08-31-2014, 11:14 AM
I also am looking forward to seeing y'all there.
As for 66 it only has two sixes, so it is not bad at all. Actually no worse than any small Philco radio, the single thing I did not like was that small mounting panel, like in 45, and it would be just fine but one bolt holding the tuning cap is under it and so you have to move it when changing the grommets etc.
Otherwise nothing extraordinary.
Remember this 75 tube wire - has to be inside the shield.....this is about it.
Oh...,and good thing is, if you need to clean your bandswitch, you do not need to remove it, the turning part will simply come out of the back, just bend out the wires and the mica cap out of the way.
