Bakelite blocks
Early caps in the uuF (pF) ranges used relatively think dielectric, from what I understand. Wider "plate" spacing in a cap lowers the capacitance and raises the DC working voltage. High voltage caps were not needed in the original circuit designs, just worked out that way due to the construction practices and materials then in manufacturing caps.
Chuck
Bakelite blocks - by Guest - 10-08-2008, 03:09 AM
Re: Bakelite blocks - by Doug K. - 10-08-2008, 06:35 AM
Re: Bakelite blocks - by Chuck Schwark - 10-08-2008, 09:30 AM
Re: Bakelite blocks - by Guest - 10-08-2008, 03:35 PM
Re: Bakelite blocks - by Ron Ramirez - 10-08-2008, 05:27 PM
Re: Bakelite blocks - by Chuck Schwark - 10-08-2008, 09:34 PM
Re: Bakelite blocks - by Guest - 10-08-2008, 10:56 PM
Re: Bakelite blocks - by mandh - 10-09-2008, 08:34 AM
Re: Bakelite blocks - by Chuck Schwark - 10-09-2008, 09:33 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3358 online users. [Complete List]
» 2 Member(s) | 3356 Guest(s)
