Philco model 37-610
Here's a puzzler - I bought a Philco 37-610 - its chassis has 6 tubes, including a 5Y3(not a 5Y4). There is no tube mounted on top of the transformer. I can't find a schematic anywhere for it. They almost all have either 5 tubes or they have a 5Y4 mounted on top of the transformer - I'm going crazy trying to find a schematic for it. Any help would be greatly appreciated. Thanks, Phil
Philco model 37-610 - by phil vanderoef - 12-22-2008, 09:27 AM
Re: Philco model 37-610 - by AI2V - 12-22-2008, 10:55 AM
Re: Philco model 37-610 - by phil vanderoef - 12-22-2008, 12:05 PM
Re: Philco model 37-610 - by BDM - 12-22-2008, 02:48 PM
Re: Philco model 37-610 - by AI2V - 12-22-2008, 04:50 PM
Re: Philco model 37-610 - by BDM - 12-22-2008, 05:10 PM
Re: Philco model 37-610 - by phil vanderoef - 12-23-2008, 08:25 AM
Re: Philco model 37-610 - by Ron Ramirez - 12-23-2008, 09:31 AM
Re: Philco model 37-610 - by Doug Houston - 12-27-2008, 06:29 PM
Re: Philco model 37-610 - by phil vanderoef - 12-30-2008, 07:58 AM
Re: Philco model 37-610 - by phil vanderoef - 12-30-2008, 08:00 AM
Re: Philco model 37-610 - by Ron Ramirez - 12-30-2008, 07:55 PM
Re: Philco model 37-610 - by Doug Houston - 12-31-2008, 08:33 PM
Re: Philco model 37-610 - by Texasrocker - 12-31-2008, 11:05 PM
Philco 91 Tuning Condenser
