philco 80 jr. help please. 1st time restoring a radio this old
thanks for the replies guys!
yes, i have been using heat shrink tubing on the wires that have breaks in the insulation.
i am replacing any wire that has to move around, such as speaker leads and control grid caps.
thanks also on the antenna clarification.
Matt
RE: philco 80 jr. help please. 1st time restoring a radio this old - by loosecannon - 08-31-2014, 08:34 PM
Users browsing this thread: 18 Guest(s)
There are currently 10213 online users. [Complete List]
» 3 Member(s) | 10210 Guest(s)
