Philco Transitone 46-250 Code 125.
As I recall, the chassis should not be held inside with any screws on the dial frame. I just looked inside my 46-806 Tropic, which is the same size as a PT-2/46-250, to confirm. I've pulled these things out before and never saw anything holding the dial frame against the front of the cabinet.
1. Note where the two wires of the loop antenna connect. Take notes, take pictures, or both. Then unsolder these leads.
2. Remove knobs.
3. Remove screws from underneath - there should be 3 - one near the back, two very close to the front.
4. Carefully slide chassis out from back.
Voila. Icon_smile
Philco Transitone 46-250 Code 125. - by morzh - 08-31-2014, 08:31 PM
RE: Philco Transitone 46-250 Code 125. - by Ron Ramirez - 09-01-2014, 06:30 AM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-01-2014, 11:32 AM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-01-2014, 12:15 PM
RE: Philco Transitone 46-250 Code 125. - by sam - 09-01-2014, 02:30 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-01-2014, 03:42 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-01-2014, 06:33 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-03-2014, 10:47 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-04-2014, 08:48 AM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-04-2014, 08:12 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-04-2014, 10:39 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-05-2014, 08:11 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-05-2014, 08:29 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-06-2014, 12:41 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-06-2014, 05:43 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-06-2014, 08:05 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-06-2014, 08:54 PM
There are currently 9916 online users. [Complete List]
» 1 Member(s) | 9915 Guest(s)
