Resistors
If you are replacing all the old paper capacitors in a simple old set, makes some sense to replace all the carbon resistors at the same time seeing as you have cleared off the terminals and so on. A fist full of resistors is only a couple of dollars, and as already stated, best fix up a set once. Carbon resistors generally drift up in value, but also develop "noise," and become heat sensitive as they age. De-soldering can, as mentioned, make them less stable. Your choice!
Resistors - by OldRestorer - 08-31-2014, 04:01 PM
RE: Resistors - by Steve Davis - 08-31-2014, 08:10 PM
RE: Resistors - by morzh - 08-31-2014, 08:23 PM
RE: Resistors - by David - 08-31-2014, 08:40 PM
RE: Resistors - by OldRestorer - 08-31-2014, 09:06 PM
RE: Resistors - by exray - 08-31-2014, 09:34 PM
RE: Resistors - by morzh - 08-31-2014, 09:49 PM
RE: Resistors - by Warren - 08-31-2014, 10:12 PM
RE: Resistors - by OldRestorer - 09-01-2014, 07:50 AM
RE: Resistors - by codefox1 - 09-01-2014, 09:43 AM
There are currently 10879 online users. [Complete List]
» 3 Member(s) | 10876 Guest(s)
