Philco 53C questions
And don't forget to check those two big resistors, part (29), mounted on top of the chassis, inside that cage at chassis right (when looking at the chassis from the rear).
Both of those resistors are open in my 53C. One of many radios and stereo receivers I have yet to get to.
Philco 53C questions - by OldRestorer - 08-25-2014, 12:40 PM
RE: Philco 53C questions - by morzh - 08-25-2014, 02:44 PM
RE: Philco 53C questions - by Eliot Ness - 08-25-2014, 03:51 PM
RE: Philco 53C questions - by Chuck Schwark - 08-25-2014, 04:01 PM
RE: Philco 53C questions - by Eliot Ness - 08-25-2014, 04:04 PM
RE: Philco 53C questions - by Chuck Schwark - 08-25-2014, 04:06 PM
RE: Philco 53C questions - by OldRestorer - 08-25-2014, 04:53 PM
RE: Philco 53C questions - by morzh - 08-25-2014, 05:13 PM
RE: Philco 53C questions - by OldRestorer - 08-29-2014, 08:32 AM
RE: Philco 53C questions - by Chuck Schwark - 08-29-2014, 09:00 AM
RE: Philco 53C questions - by morzh - 08-29-2014, 11:32 AM
RE: Philco 53C questions - by OldRestorer - 08-31-2014, 01:03 PM
RE: Philco 53C questions - by morzh - 08-31-2014, 01:55 PM
RE: Philco 53C questions - by PhilcoJohn - 08-31-2014, 06:46 PM
RE: Philco 53C questions - by morzh - 08-31-2014, 07:01 PM
RE: Philco 53C questions - by OldRestorer - 09-01-2014, 09:47 AM
RE: Philco 53C questions - by morzh - 09-01-2014, 12:37 PM
RE: Philco 53C questions - by OldRestorer - 09-01-2014, 01:06 PM
RE: Philco 53C questions - by sam - 09-01-2014, 02:13 PM
RE: Philco 53C questions - by tab10672 - 09-01-2014, 03:18 PM
RE: Philco 53C questions - by morzh - 09-01-2014, 03:39 PM
RE: Philco 53C questions - by OldRestorer - 09-01-2014, 05:35 PM
RE: Philco 53C questions - by sam - 09-01-2014, 06:07 PM
RE: Philco 53C questions - by morzh - 09-01-2014, 06:31 PM
RE: Philco 53C questions - by Warren - 09-01-2014, 06:31 PM
RE: Philco 53C questions - by Ron Ramirez - 09-01-2014, 07:30 PM
RE: Philco 53C questions - by OldRestorer - 09-01-2014, 07:32 PM
RE: Philco 53C questions - by morzh - 09-01-2014, 07:37 PM
RE: Philco 53C questions - by OldRestorer - 09-01-2014, 08:06 PM
RE: Philco 53C questions - by morzh - 09-01-2014, 08:40 PM
RE: Philco 53C questions - by OldRestorer - 09-05-2014, 01:12 PM
RE: Philco 53C questions - by Ron Ramirez - 09-05-2014, 01:15 PM
RE: Philco 53C questions - by morzh - 09-05-2014, 01:33 PM
RE: Philco 53C questions - by OldRestorer - 09-05-2014, 02:15 PM
RE: Philco 53C questions - by morzh - 09-05-2014, 02:46 PM
RE: Philco 53C questions - by morzh - 09-05-2014, 02:51 PM
There are currently 7518 online users. [Complete List]
» 2 Member(s) | 7516 Guest(s)
