philco 80 jr. help please. 1st time restoring a radio this old
thanks guys,
from what has been suggested here along with what i have learned by searching the phorum; i think i am just going to clean the cabinet with the pumice free gojo cleaner, and then wipe some "howards" on it.
again, im not going to be "restoring" the cabinet, just cleaning it up to make it look nicer.
always open to more suggestions though!
Matt
RE: philco 80 jr. help please. 1st time restoring a radio this old - by loosecannon - 09-01-2014, 08:16 PM
There are currently 9922 online users. [Complete List]
» 1 Member(s) | 9921 Guest(s)
