Amazing 16B
Excelent job.
It is as shiny as cat's you know what.
I hope it works half as well as it looks, quite enough.
Congrats, any 16 is a great radio, an this one is epecially good looking.
Amazing 16B - by fields 100 - 09-01-2014, 08:37 PM
RE: Amazing 16B - by morzh - 09-01-2014, 08:43 PM
RE: Amazing 16B - by fields 100 - 09-01-2014, 09:28 PM
RE: Amazing 16B - by Arran - 09-02-2014, 12:00 AM
RE: Amazing 16B - by fields 100 - 09-02-2014, 07:14 AM
RE: Amazing 16B - by Ron Ramirez - 09-02-2014, 08:28 AM
RE: Amazing 16B - by Art Hoch - 09-02-2014, 01:50 PM
There are currently 5513 online users. [Complete List]
» 1 Member(s) | 5512 Guest(s)
