1938 Philco Chevron Cloth available again
Is the 1938 cloth the same stuff that was used on the 1939 sets or is that different again?
RE: 1938 Philco Chevron Cloth available again - by Arran - 09-01-2014, 11:25 PM
There are currently 11417 online users. [Complete List]
» 2 Member(s) | 11415 Guest(s)
