1938 Philco Chevron Cloth available again
Either that, or Philco only used the 1938 chevron in the preproduction sample and then used the other pattern in production.
You know that Philco was famous (infamous?) for their running changes in production, not all of which were documented...
RE: 1938 Philco Chevron Cloth available again - by Ron Ramirez - 09-02-2014, 08:32 AM
There are currently 11394 online users. [Complete List]
» 2 Member(s) | 11392 Guest(s)
