  • 1 Vote(s) - 5 Average
mute philco 19 or 89 or all between
#57
I'm curious! What is the difference from the original coil as opposed to the one I'm thinking about. I see the physical differences such as structure. I removed the iron core which was falling apart anyway. I did notice the wire when spun on it's core looks braided as opposed to what a sewing machine type bobber which goes back and forth or side to side for even coverage. The original has a wooden core where the other has a paper one. Neither of the windings are physically touching except the base on which they were spun.
You guys are obviously the experts and I am the lowly student, so to speak. Some things make sense but this one kind of quirky.
Even after all this I have this bad feeling it's still not going to work.
RE: mute philco 19 or 89 or all between - by confused2 - 08-29-2014, 09:37 AM
RE: mute philco 19 or 89 or all between - by confused2 - 08-29-2014, 09:51 AM
RE: mute philco 19 or 89 or all between - by confused1 - 09-03-2014, 12:04 AM
Users browsing this thread: 20 Guest(s)
There are currently 10380 online users. [Complete List]
» 1 Member(s) | 10379 Guest(s)
