  • 1 Vote(s) - 5 Average
Philco 70
There were two versions of the 70 but the cabinets look the same. Are you referring to the profile of the outer edge of the arch? There were some slight variations of this profile from one cabinet to the next but none were completely flat that I know of. Is there any way you can post a picture?
M R Radios   C M Tubes
Philco 70 - by fields 100 - 09-03-2014, 05:17 PM
RE: Philco 70 - by Steve Davis - 09-03-2014, 06:28 PM
RE: Philco 70 - by fields 100 - 09-03-2014, 06:53 PM
RE: Philco 70 - by tab10672 - 09-03-2014, 07:21 PM
RE: Philco 70 - by fields 100 - 09-03-2014, 08:27 PM
