Mystery 1940s Philco
There is currently a Philco AM/SW Phonograph console on Ebay:
http://www.ebay.com/itm/Antique-30s-PHIL...4d22190bd6
which seems similar to some of the lost 1942 models and to some of the 1946-47 models but does not match any of them exactly. Any idea what model this actually is?
Joe
Mystery 1940s Philco - by Joeztech - 09-04-2014, 09:09 AM
RE: Mystery 1940s Philco - by tab10672 - 09-04-2014, 10:54 AM
RE: Mystery 1940s Philco - by OldRestorer - 09-04-2014, 10:58 AM
RE: Mystery 1940s Philco - by tab10672 - 09-04-2014, 11:04 AM
RE: Mystery 1940s Philco - by morzh - 09-04-2014, 11:30 AM
RE: Mystery 1940s Philco - by Joeztech - 09-04-2014, 11:46 AM
RE: Mystery 1940s Philco - by Marsupial - 09-04-2014, 12:18 PM
RE: Mystery 1940s Philco - by radiohenry - 09-06-2014, 08:00 AM
RE: Mystery 1940s Philco - by Ron Ramirez - 09-06-2014, 08:04 AM
RE: Mystery 1940s Philco - by radiohenry - 09-06-2014, 08:23 AM
