Philco 90 Dial movement
This photo should prove helpful:
[Image: http://i326.photobucket.com/albums/k420/...0drive.jpg]
Notice the entire lack of any rubber, or dial cord; only metal-to-metal contact.
Philco 90 Dial movement - by Guest - 10-02-2008, 03:21 PM
Re: Philco 90 Dial movement - by Chuck Schwark - 10-02-2008, 03:39 PM
Re: Philco 90 Dial movement - by etech - 10-12-2008, 11:01 AM
Re: Philco 90 Dial movement - by Ron Ramirez - 10-12-2008, 11:10 AM
Re: Philco 90 Dial movement - by etech - 10-12-2008, 07:50 PM
Re: Philco 90 Dial movement - by Ron Ramirez - 10-12-2008, 10:35 PM
Re: Philco 90 Dial movement - by Guest - 10-13-2008, 07:23 AM
Re: Philco 90 Dial movement - by etech - 10-13-2008, 08:26 AM
Re: Philco 90 Dial movement - by Ron Ramirez - 10-13-2008, 07:06 PM
Re: Philco 90 Dial movement - by Tim Tress - 11-13-2008, 09:14 PM
Philco 91 Tuning Condenser
