  • 1 Vote(s) - 5 Average
Philco 49-607 questions
If I have posted this before I apologize, but I am new here and never have seen the post.
Can someone please tell me what the metal strap holders where plated with.
Also it appers that the wood used for the cabinet was walnut, however it appears that a curved piece of pine was used on the rear top. Can you tell me what the original cabinet was stained with? Were there 2 different stains used?
Philco 49-607 questions - by mornflt - 09-04-2014, 04:31 PM
RE: Philco 49-607 questions - by tab10672 - 09-04-2014, 06:37 PM
RE: Philco 49-607 questions - by mornflt - 09-04-2014, 07:39 PM
RE: Philco 49-607 questions - by tab10672 - 09-04-2014, 08:06 PM
RE: Philco 49-607 questions - by OldRestorer - 09-04-2014, 08:16 PM
RE: Philco 49-607 questions - by morzh - 09-04-2014, 10:58 PM
RE: Philco 49-607 questions - by Arran - 09-04-2014, 11:27 PM
RE: Philco 49-607 questions - by codefox1 - 09-06-2014, 09:55 AM
RE: Philco 49-607 questions - by mornflt - 09-06-2014, 01:01 PM
RE: Philco 49-607 questions - by OldRestorer - 09-06-2014, 03:39 PM
RE: Philco 49-607 questions - by Arran - 09-07-2014, 03:00 AM
RE: Philco 49-607 questions - by mornflt - 09-07-2014, 03:56 PM
RE: Philco 49-607 questions - by sam - 09-07-2014, 05:11 PM
RE: Philco 49-607 questions - by Arran - 09-07-2014, 10:19 PM
