  • 1 Vote(s) - 5 Average
mute philco 19 or 89 or all between
#65
Well here's the news.
I made the coils about the same as the original, soldered and put it all back together. I think I'm on the right track.
I got very faint noise.....whining , faint static and hissing where I got nothing before. I got it in the middle of the dial where before it was quiet.
I think I found the problem and need to get a new part. By what I've gone through with this radio it seems narrowed down to the IF coil after all.
YEAHHH!!!!!!
Now to find the part.........sad face!
RE: mute philco 19 or 89 or all between - by confused2 - 08-29-2014, 09:37 AM
RE: mute philco 19 or 89 or all between - by confused2 - 08-29-2014, 09:51 AM
RE: mute philco 19 or 89 or all between - by confused1 - 09-04-2014, 04:38 PM
There are currently 9942 online users. [Complete List]
» 3 Member(s) | 9939 Guest(s)
