  • 1 Vote(s) - 5 Average
Philco 49-607 questions
Mine looks to be copper or copper plated.
Philco 49-607 questions - by mornflt - 09-04-2014, 04:31 PM
RE: Philco 49-607 questions - by tab10672 - 09-04-2014, 06:37 PM
RE: Philco 49-607 questions - by mornflt - 09-04-2014, 07:39 PM
RE: Philco 49-607 questions - by tab10672 - 09-04-2014, 08:06 PM
RE: Philco 49-607 questions - by OldRestorer - 09-04-2014, 08:16 PM
RE: Philco 49-607 questions - by morzh - 09-04-2014, 10:58 PM
RE: Philco 49-607 questions - by Arran - 09-04-2014, 11:27 PM
RE: Philco 49-607 questions - by codefox1 - 09-06-2014, 09:55 AM
RE: Philco 49-607 questions - by mornflt - 09-06-2014, 01:01 PM
RE: Philco 49-607 questions - by OldRestorer - 09-06-2014, 03:39 PM
RE: Philco 49-607 questions - by Arran - 09-07-2014, 03:00 AM
RE: Philco 49-607 questions - by mornflt - 09-07-2014, 03:56 PM
RE: Philco 49-607 questions - by sam - 09-07-2014, 05:11 PM
RE: Philco 49-607 questions - by Arran - 09-07-2014, 10:19 PM
