Philco 53C questions
#32
If one or both resistors were open, the tubes would not light up (they are part of the series filament string).
If you had installed an electrolytic backwards, you would have known it right away by the loud POW! like a firecracker or gunshot from the electrolytic failing from being connected backwards.
So...so far so good, it seems...
Philco 53C questions - by OldRestorer - 08-25-2014, 12:40 PM
RE: Philco 53C questions - by morzh - 08-25-2014, 02:44 PM
RE: Philco 53C questions - by Eliot Ness - 08-25-2014, 03:51 PM
RE: Philco 53C questions - by Chuck Schwark - 08-25-2014, 04:01 PM
RE: Philco 53C questions - by Eliot Ness - 08-25-2014, 04:04 PM
RE: Philco 53C questions - by Chuck Schwark - 08-25-2014, 04:06 PM
RE: Philco 53C questions - by OldRestorer - 08-25-2014, 04:53 PM
RE: Philco 53C questions - by morzh - 08-25-2014, 05:13 PM
RE: Philco 53C questions - by OldRestorer - 08-29-2014, 08:32 AM
RE: Philco 53C questions - by Chuck Schwark - 08-29-2014, 09:00 AM
RE: Philco 53C questions - by morzh - 08-29-2014, 11:32 AM
RE: Philco 53C questions - by OldRestorer - 08-31-2014, 01:03 PM
RE: Philco 53C questions - by morzh - 08-31-2014, 01:55 PM
RE: Philco 53C questions - by PhilcoJohn - 08-31-2014, 06:46 PM
RE: Philco 53C questions - by morzh - 08-31-2014, 07:01 PM
RE: Philco 53C questions - by OldRestorer - 09-01-2014, 09:47 AM
RE: Philco 53C questions - by morzh - 09-01-2014, 12:37 PM
RE: Philco 53C questions - by OldRestorer - 09-01-2014, 01:06 PM
RE: Philco 53C questions - by sam - 09-01-2014, 02:13 PM
RE: Philco 53C questions - by tab10672 - 09-01-2014, 03:18 PM
RE: Philco 53C questions - by morzh - 09-01-2014, 03:39 PM
RE: Philco 53C questions - by OldRestorer - 09-01-2014, 05:35 PM
RE: Philco 53C questions - by sam - 09-01-2014, 06:07 PM
RE: Philco 53C questions - by morzh - 09-01-2014, 06:31 PM
RE: Philco 53C questions - by Warren - 09-01-2014, 06:31 PM
RE: Philco 53C questions - by Ron Ramirez - 09-01-2014, 07:30 PM
RE: Philco 53C questions - by OldRestorer - 09-01-2014, 07:32 PM
RE: Philco 53C questions - by morzh - 09-01-2014, 07:37 PM
RE: Philco 53C questions - by OldRestorer - 09-01-2014, 08:06 PM
RE: Philco 53C questions - by morzh - 09-01-2014, 08:40 PM
RE: Philco 53C questions - by OldRestorer - 09-05-2014, 01:12 PM
RE: Philco 53C questions - by Ron Ramirez - 09-05-2014, 01:15 PM
RE: Philco 53C questions - by morzh - 09-05-2014, 01:33 PM
RE: Philco 53C questions - by OldRestorer - 09-05-2014, 02:15 PM
RE: Philco 53C questions - by morzh - 09-05-2014, 02:46 PM
RE: Philco 53C questions - by morzh - 09-05-2014, 02:51 PM
There are currently 9598 online users. [Complete List]
» 3 Member(s) | 9595 Guest(s)
