37 620 decal
It appears to be a bit off center (just a bit too far to the right) in the photo.
However, the PHILCO decals were not always 100% centered from the factory. When these things were being built, the decals were applied by humans who made errors. If the error was minor, the cabinet went out the door anyway. Thus my comment, "that will work." Icon_smile
37 620 decal - by OldRestorer - 09-04-2014, 01:07 PM
RE: 37 620 decal - by Ron Ramirez - 09-04-2014, 06:21 PM
RE: 37 620 decal - by OldRestorer - 09-04-2014, 06:27 PM
RE: 37 620 decal - by morzh - 09-04-2014, 06:49 PM
RE: 37 620 decal - by OldRestorer - 09-05-2014, 12:15 PM
RE: 37 620 decal - by Ron Ramirez - 09-05-2014, 12:19 PM
RE: 37 620 decal - by OldRestorer - 09-05-2014, 12:23 PM
RE: 37 620 decal - by OldRestorer - 09-05-2014, 12:54 PM
RE: 37 620 decal - by Ron Ramirez - 09-05-2014, 12:59 PM
RE: 37 620 decal - by OldRestorer - 09-05-2014, 01:14 PM
RE: 37 620 decal - by Ron Ramirez - 09-05-2014, 01:19 PM
RE: 37 620 decal - by morzh - 09-05-2014, 01:45 PM
RE: 37 620 decal - by codefox1 - 09-06-2014, 09:33 AM
RE: 37 620 decal - by Ron Ramirez - 09-06-2014, 10:25 PM
RE: 37 620 decal - by morzh - 09-06-2014, 10:28 PM
RE: 37 620 decal - by Ron Ramirez - 09-06-2014, 10:33 PM
RE: 37 620 decal - by morzh - 09-06-2014, 11:00 PM
RE: 37 620 decal - by sam - 09-07-2014, 12:40 AM
RE: 37 620 decal - by OldRestorer - 09-07-2014, 02:30 PM
RE: 37 620 decal - by Ron Ramirez - 09-08-2014, 05:45 AM
RE: 37 620 decal - by OldRestorer - 09-08-2014, 07:52 AM
RE: 37 620 decal - by morzh - 09-08-2014, 08:43 AM
RE: 37 620 decal - by OldRestorer - 09-08-2014, 09:59 AM
There are currently 11394 online users. [Complete List]
» 2 Member(s) | 11392 Guest(s)
