SW aerial
Never tried 75ohm on short wave receiver. To transmit you need RG58 ie 2 meter band to Hf bands. Have used single long wire to receive also 300 ohm or 400 ohm ladder lead with diapole ant. For 300 ohm twin lead try amazon.com cost around 15 dollars for 100 feet. David
SW aerial - by fields 100 - 03-11-2014, 08:46 AM
RE: SW aerial - by morzh - 03-11-2014, 01:46 PM
RE: SW aerial - by Art Hoch - 03-11-2014, 10:04 PM
RE: SW aerial - by captainslack - 03-12-2014, 02:21 PM
RE: SW aerial - by Eric T - 03-12-2014, 08:55 PM
RE: SW aerial - by Radioroslyn - 03-13-2014, 08:18 AM
RE: SW aerial - by fields 100 - 03-13-2014, 09:01 AM
RE: SW aerial - by David - 03-13-2014, 01:42 PM
RE: SW aerial - by Radioroslyn - 03-13-2014, 05:28 PM
RE: SW aerial - by fields 100 - 03-13-2014, 06:29 PM
RE: SW aerial - by fields 100 - 09-03-2014, 09:39 AM
RE: SW aerial - by morzh - 09-03-2014, 09:48 AM
RE: SW aerial - by fields 100 - 09-03-2014, 11:42 AM
RE: SW aerial - by morzh - 09-03-2014, 11:56 AM
RE: SW aerial - by Mondial - 09-03-2014, 02:12 PM
RE: SW aerial - by David - 09-05-2014, 03:51 PM
RE: SW aerial - by David - 09-05-2014, 06:14 PM
RE: SW aerial - by fields 100 - 09-16-2014, 06:25 PM
RE: SW aerial - by David - 09-17-2014, 09:04 AM
RE: SW aerial - by PhilcoJohn - 09-17-2014, 07:44 PM
RE: SW aerial - by fields 100 - 09-17-2014, 10:01 PM
RE: SW aerial - by Mondial - 09-17-2014, 10:08 PM
RE: SW aerial - by David - 09-19-2014, 08:17 PM
There are currently 10578 online users. [Complete List]
» 3 Member(s) | 10575 Guest(s)
