Philco 42-395
It's a very good performer. Too bad it has that now-useless old FM band (42 to 50 mc).
As you know, no-one reproduces this escutcheon (some 1942 Philco radio-phonograph consoles use the same escutcheon).
Philco 42-395 - by Guest - 10-12-2008, 07:36 AM
RE: Philco 42-395 - by lasttoknow - 05-25-2012, 12:23 PM
Re: Philco 42-395 - by Ron Ramirez - 10-12-2008, 11:14 AM
Re: Philco 42-395 - by Guest - 10-12-2008, 12:40 PM
Re: Philco 42-395 - by Ron Ramirez - 10-13-2008, 07:09 PM
Re: Philco 42-395 - by Guest - 11-15-2008, 10:38 AM
Re: Philco 42-395 - by Ron Ramirez - 11-15-2008, 02:49 PM
Re: Philco 42-395 - by Guest - 11-15-2008, 03:32 PM
Re: Philco 42-395 - by Guest - 12-28-2008, 04:50 PM
Re: Philco 42-395 - by Doug Houston - 12-28-2008, 05:14 PM
Re: Philco 42-395 - by Guest - 12-28-2008, 06:16 PM
Re: Philco 42-395 - by 49Stude63 - 12-30-2008, 01:20 PM
Re: Philco 42-395 - by Guest - 12-30-2008, 02:06 PM
Re: Philco 42-395 - by 49Stude63 - 12-30-2008, 02:10 PM
Re: Philco 42-395 - by Guest - 12-30-2008, 02:25 PM
Philco 91 Tuning Condenser
There are currently 3677 online users. [Complete List]
» 1 Member(s) | 3676 Guest(s)
