Philco model 10 speaker
Model 10??? That should be Model F-10.
Models 65, 76 and 95 table models use the large speaker plug; Models 77 and 96 table models would use the small speaker plug. The two variations of the table model speaker are otherwise identical.
Oh, and the table model is also pictured in the June 1929 and Fall 1929 Gallery pages.
Philco model 10 speaker - by Guest - 10-03-2008, 12:12 PM
Re: Philco model 10 speaker - by Ron Ramirez - 10-13-2008, 07:13 PM
Re: Philco model 10 speaker - by Guest - 10-15-2008, 10:50 AM
There are currently 10880 online users. [Complete List]
» 2 Member(s) | 10878 Guest(s)
