Newbie Neophyte Question
Hi and welcome.
Unlike your 41-295, your 39-40's off-on toggle switch just under the top edge of the speaker grille is original. Philco did not start using the far left pushbutton for an off-on switch until the 1941 season.
This means all eight pushbuttons on your 39-40 may be set to favorite AM stations, not just the last seven as on your 41-295.
Newbie Neophyte Question - by Guest - 11-15-2008, 10:23 AM
Re: Newbie Neophyte Question - by Ron Ramirez - 11-15-2008, 10:36 AM
Re: Newbie Neophyte Question - by Guest - 11-15-2008, 01:19 PM
Re: Newbie Neophyte Question - by Ron Ramirez - 11-15-2008, 02:47 PM
Re: Newbie Neophyte Question - by Texasrocker - 11-16-2008, 12:01 AM
Re: Newbie Neophyte Question - by Guest - 11-16-2008, 02:27 PM
Re: Newbie Neophyte Question - by Jim Berg - 11-20-2008, 10:49 PM
Re: Newbie Neophyte Question - by Ron Ramirez - 11-20-2008, 11:16 PM
Philco 91 Tuning Condenser
There are currently 8883 online users. [Complete List]
» 2 Member(s) | 8881 Guest(s)
