Philco Transitone 46-250 Code 125.
Aligned it.
Works just fine!
Will try to find a repro back cover. Those wires from the loop are unsightly.
Hope this is it!
PS. Found on eBay and outside (same company, Retro-tronics).
Realized I only have one clip that holds it in the back.
Anyone knows where to get those?
Philco Transitone 46-250 Code 125. - by morzh - 08-31-2014, 08:31 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-01-2014, 11:32 AM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-01-2014, 12:15 PM
RE: Philco Transitone 46-250 Code 125. - by sam - 09-01-2014, 02:30 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-01-2014, 03:42 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-01-2014, 06:33 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-03-2014, 10:47 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-04-2014, 08:48 AM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-04-2014, 08:12 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-04-2014, 10:39 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-05-2014, 08:11 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-05-2014, 08:29 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-06-2014, 12:41 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-06-2014, 05:43 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-06-2014, 08:05 PM
RE: Philco Transitone 46-250 Code 125. - by morzh - 09-06-2014, 08:54 PM
There are currently 10019 online users. [Complete List]
» 2 Member(s) | 10017 Guest(s)
