37 620 decal
It looks to me like the "I" in "PHILCO" is almost right on the centerline.
Nevertheless...
Kirk, leave it alone. It's good enough. It will look like a Philco employee didn't get the original decal 100% centered. Like I said, there are some, perhaps several, Philco radios with off-center original decals.
37 620 decal - by OldRestorer - 09-04-2014, 01:07 PM
RE: 37 620 decal - by Ron Ramirez - 09-04-2014, 06:21 PM
RE: 37 620 decal - by OldRestorer - 09-04-2014, 06:27 PM
RE: 37 620 decal - by morzh - 09-04-2014, 06:49 PM
RE: 37 620 decal - by OldRestorer - 09-05-2014, 12:15 PM
RE: 37 620 decal - by Ron Ramirez - 09-05-2014, 12:19 PM
RE: 37 620 decal - by OldRestorer - 09-05-2014, 12:23 PM
RE: 37 620 decal - by OldRestorer - 09-05-2014, 12:54 PM
RE: 37 620 decal - by Ron Ramirez - 09-05-2014, 12:59 PM
RE: 37 620 decal - by OldRestorer - 09-05-2014, 01:14 PM
RE: 37 620 decal - by Ron Ramirez - 09-05-2014, 01:19 PM
RE: 37 620 decal - by morzh - 09-05-2014, 01:45 PM
RE: 37 620 decal - by codefox1 - 09-06-2014, 09:33 AM
RE: 37 620 decal - by Ron Ramirez - 09-06-2014, 10:25 PM
RE: 37 620 decal - by morzh - 09-06-2014, 10:28 PM
RE: 37 620 decal - by Ron Ramirez - 09-06-2014, 10:33 PM
RE: 37 620 decal - by morzh - 09-06-2014, 11:00 PM
RE: 37 620 decal - by sam - 09-07-2014, 12:40 AM
RE: 37 620 decal - by OldRestorer - 09-07-2014, 02:30 PM
RE: 37 620 decal - by Ron Ramirez - 09-08-2014, 05:45 AM
RE: 37 620 decal - by OldRestorer - 09-08-2014, 07:52 AM
RE: 37 620 decal - by morzh - 09-08-2014, 08:43 AM
RE: 37 620 decal - by OldRestorer - 09-08-2014, 09:59 AM
There are currently 10135 online users. [Complete List]
» 2 Member(s) | 10133 Guest(s)
