philco 80 jr. help please. 1st time restoring a radio this old
#39
Sorry LC if I added a little confusion. I was looking at the schematic for the 80 that was posted earlier. It seems to indicate that item 37 is a 10mfd. I couldn't find a parts list on the posting. Take a peak at this link under the 80.
Jerry
http://www.nostalgiaair.org/PagesByModel...013843.pdf
RE: philco 80 jr. help please. 1st time restoring a radio this old - by jerryhawthorne - 09-07-2014, 02:26 AM
Users browsing this thread: 13 Guest(s)
