philco 80 jr. help please. 1st time restoring a radio this old
#40
In this scheme there is also a capacitor #38 of .01, no other existing schemes.
RE: philco 80 jr. help please. 1st time restoring a radio this old - by Pillo69 - 09-07-2014, 07:38 AM
Users browsing this thread: 16 Guest(s)
There are currently 9707 online users. [Complete List]
» 3 Member(s) | 9704 Guest(s)
