philco 80 jr. help please. 1st time restoring a radio this old
#41
Jerry
What you refer to as #37 is not a lytic, it is a backelite paper cap across the wirewound resistor.
RE: philco 80 jr. help please. 1st time restoring a radio this old - by morzh - 09-07-2014, 09:54 AM
Users browsing this thread: 13 Guest(s)
There are currently 9628 online users. [Complete List]
» 3 Member(s) | 9625 Guest(s)
