ACDC sets with replaced curtain burners.
0.3A is a very light load for a diode rated at 1A. At Vf about 0.85V at 0.3A the power dissipated across the diode is 1/4W which is nothing.
And, if you take into account the duty cycle of 2 that cuts the power in half....this diode is mre than adequate.
No need for 3A diode. At all.
RE: ACDC sets with replaced curtain burners. - by morzh - 09-07-2014, 10:02 AM
