Crosley 167 Tombstone a little show and tell.
And here is is after some scrubbing with fine steel wool and wiping down with damp paper towels. I did cheat and ran some water on the tight spots to rinse and used the air hose to dry. Afterwards only some minor pitting at the front top of chassis. I also found that navel jelly cleans up brass pretty well.
RE: Crosley 167 Tombstone a little show and tell. - by OZ4 - 09-08-2014, 04:15 PM
Eico 232 VTVM Schematic
There are currently 9407 online users. [Complete List]
» 2 Member(s) | 9405 Guest(s)
