Murdock Neutradyne?
Don't know but it doesn't matter much there all about same. Check the audio xformers and rf coils. Looks like it may be a homemade job.
Murdock Neutradyne? - by OZ4 - 09-08-2014, 03:12 PM
RE: Murdock Neutradyne? - by OZ4 - 09-08-2014, 03:14 PM
RE: Murdock Neutradyne? - by Radioroslyn - 09-08-2014, 06:00 PM
RE: Murdock Neutradyne? - by OZ4 - 09-08-2014, 06:45 PM
RE: Murdock Neutradyne? - by Eliot Ness - 09-08-2014, 07:43 PM
RE: Murdock Neutradyne? - by Arran - 09-09-2014, 03:01 AM
RE: Murdock Neutradyne? - by OZ4 - 09-10-2014, 12:42 AM
RE: Murdock Neutradyne? - by tab10672 - 09-10-2014, 02:06 PM
RE: Murdock Neutradyne? - by Radioroslyn - 09-14-2014, 06:41 PM
RE: Murdock Neutradyne? - by OZ4 - 09-14-2014, 07:46 PM
