Not a good sound...
Ok so I was testing the 37-620 cathedral after a full recap and I am getting a real loud base squealing. If i turn the tone control it get higher pitched and then starts sputtering intermittently.
It was not making any sound at first so I checked all the tubes and cleaned the controls but now this is happening..
What the heck did I do?
Kirk
Not a good sound... - by OldRestorer - 09-08-2014, 08:16 PM
RE: Not a good sound... - by Mondial - 09-08-2014, 08:37 PM
RE: Not a good sound... - by morzh - 09-08-2014, 08:39 PM
RE: Not a good sound... - by exray - 09-08-2014, 08:40 PM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 07:28 AM
RE: Not a good sound... - by Eliot Ness - 09-09-2014, 07:55 AM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 08:24 AM
RE: Not a good sound... - by morzh - 09-09-2014, 09:00 AM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 10:42 AM
RE: Not a good sound... - by codefox1 - 09-09-2014, 11:05 AM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 12:16 PM
RE: Not a good sound... - by Eliot Ness - 09-09-2014, 12:38 PM
RE: Not a good sound... - by Phlogiston - 09-10-2014, 11:08 AM
RE: Not a good sound... - by morzh - 09-10-2014, 03:14 PM
RE: Not a good sound... - by OldRestorer - 09-10-2014, 05:16 PM
RE: Not a good sound... - by Phlogiston - 09-10-2014, 11:36 PM
RE: Not a good sound... - by OldRestorer - 09-11-2014, 01:47 PM
RE: Not a good sound... - by morzh - 09-11-2014, 03:01 PM
RE: Not a good sound... - by Phlogiston - 09-11-2014, 11:30 PM
There are currently 7222 online users. [Complete List]
» 1 Member(s) | 7221 Guest(s)
