Not a good sound...
Replace the socket if you can't clean and re-tension. You can also get a 6Q7 (metal version,) and make sure pin 1 is not used as a tie point for anything other than ground (re route if needed,) and then ground pin1.
Not a good sound... - by OldRestorer - 09-08-2014, 08:16 PM
RE: Not a good sound... - by Mondial - 09-08-2014, 08:37 PM
RE: Not a good sound... - by morzh - 09-08-2014, 08:39 PM
RE: Not a good sound... - by exray - 09-08-2014, 08:40 PM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 07:28 AM
RE: Not a good sound... - by Eliot Ness - 09-09-2014, 07:55 AM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 08:24 AM
RE: Not a good sound... - by morzh - 09-09-2014, 09:00 AM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 10:42 AM
RE: Not a good sound... - by codefox1 - 09-09-2014, 11:05 AM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 12:16 PM
RE: Not a good sound... - by Eliot Ness - 09-09-2014, 12:38 PM
RE: Not a good sound... - by Phlogiston - 09-10-2014, 11:08 AM
RE: Not a good sound... - by morzh - 09-10-2014, 03:14 PM
RE: Not a good sound... - by OldRestorer - 09-10-2014, 05:16 PM
RE: Not a good sound... - by Phlogiston - 09-10-2014, 11:36 PM
RE: Not a good sound... - by OldRestorer - 09-11-2014, 01:47 PM
RE: Not a good sound... - by morzh - 09-11-2014, 03:01 PM
RE: Not a good sound... - by Phlogiston - 09-11-2014, 11:30 PM
There are currently 9901 online users. [Complete List]
» 1 Member(s) | 9900 Guest(s)
