Not a good sound...
Quote:The base is loose, as is the top contact so I dont know...
You can re-glue the base as well as the top cap with a drop or two of glue. Then you can heat up each tube pin and flow in some fresh solder. That would eliminate a flaky connection at one of the tube pins. Also try lightly tapping the tube when testing, especially when testing for shorts.
Not a good sound... - by OldRestorer - 09-08-2014, 08:16 PM
RE: Not a good sound... - by Mondial - 09-08-2014, 08:37 PM
RE: Not a good sound... - by morzh - 09-08-2014, 08:39 PM
RE: Not a good sound... - by exray - 09-08-2014, 08:40 PM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 07:28 AM
RE: Not a good sound... - by Eliot Ness - 09-09-2014, 07:55 AM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 08:24 AM
RE: Not a good sound... - by morzh - 09-09-2014, 09:00 AM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 10:42 AM
RE: Not a good sound... - by codefox1 - 09-09-2014, 11:05 AM
RE: Not a good sound... - by OldRestorer - 09-09-2014, 12:16 PM
RE: Not a good sound... - by Eliot Ness - 09-09-2014, 12:38 PM
RE: Not a good sound... - by Phlogiston - 09-10-2014, 11:08 AM
RE: Not a good sound... - by morzh - 09-10-2014, 03:14 PM
RE: Not a good sound... - by OldRestorer - 09-10-2014, 05:16 PM
RE: Not a good sound... - by Phlogiston - 09-10-2014, 11:36 PM
RE: Not a good sound... - by OldRestorer - 09-11-2014, 01:47 PM
RE: Not a good sound... - by morzh - 09-11-2014, 03:01 PM
RE: Not a good sound... - by Phlogiston - 09-11-2014, 11:30 PM
There are currently 6646 online users. [Complete List]
» 2 Member(s) | 6644 Guest(s)
