16B cathedral
They are just wheel polished with a compound. So far I have not noticed any oxidation.I could have also nickel plated them, but there is a minimum charge which is steep for just one set of shields.One day I'll take them from all radios and plate them. Shields were easy thing to do. The rivet thing drove me nuts.
16B cathedral - by fields 100 - 09-09-2014, 08:39 AM
RE: 16B cathedral - by Mondial - 09-09-2014, 03:08 PM
RE: 16B cathedral - by fields 100 - 09-09-2014, 03:57 PM
There are currently 6984 online users. [Complete List]
» 1 Member(s) | 6983 Guest(s)
