Philco Grille Cloth
Hi Ron.
It is off the Philco 98 series 2 (export) we discussed a while back.
I am about to update that post with a new development.
I have just acquired another 98. this time a series 1.
Both cabinets are the same apart from the through front stud bolts on the series 1.
At This stage I am concluding that the cabinets were made in the UK.
The grill Cloth is exactly the same in both the 98 series 1 and 2.
So I am thinking that if the grille cloth is absent from the US . That is another indicator for UK manufacture of the cabinets.
Regards.
Willie.
Philco Grille Cloth - by HOTWIRE - 09-09-2014, 03:27 PM
RE: Philco Grille Cloth - by Eric Adams - 09-09-2014, 03:52 PM
RE: Philco Grille Cloth - by Ron Ramirez - 09-09-2014, 04:01 PM
RE: Philco Grille Cloth - by HOTWIRE - 09-09-2014, 04:24 PM
RE: Philco Grille Cloth - by Ron Ramirez - 09-09-2014, 04:37 PM
RE: Philco Grille Cloth - by Arran - 09-09-2014, 10:33 PM
RE: Philco Grille Cloth - by OldRestorer - 09-10-2014, 11:55 AM
RE: Philco Grille Cloth - by HOTWIRE - 09-12-2014, 04:49 PM
RE: Philco Grille Cloth - by HOTWIRE - 09-16-2014, 02:33 PM
RE: Philco Grille Cloth - by Ron Ramirez - 09-16-2014, 04:16 PM
RE: Philco Grille Cloth - by HOTWIRE - 09-17-2014, 01:05 PM
RE: Philco Grille Cloth - by HOTWIRE - 01-24-2015, 11:14 AM
