Model 60, reattaching dial, where to index back to?
Hi
There should be an index line below 55 on the dial. That would be where you set it, with the plates of the tuning condenser fully meshed.
Re: Model 60, reattaching dial, where to index back to? - by Ron Ramirez - 10-17-2008, 06:45 AM
The speaker table error?
Philco 70 antenna lead
