Question about 118b
If the bleeder is #60 (a big long wirewound), same one I had in 18. Not very elegant solution to lower B+, also increases current through the field coil and the filter choke, which does not add to longevity...
Question about 118b - by fields 100 - 09-09-2014, 05:14 PM
RE: Question about 118b - by Steve Chambers - 09-09-2014, 07:39 PM
RE: Question about 118b - by SteveJB - 09-09-2014, 08:51 PM
RE: Question about 118b - by Arran - 09-09-2014, 10:25 PM
RE: Question about 118b - by morzh - 09-10-2014, 09:04 AM
RE: Question about 118b - by Ron Ramirez - 09-10-2014, 09:35 AM
RE: Question about 118b - by morzh - 09-10-2014, 03:04 PM
RE: Question about 118b - by fields 100 - 09-10-2014, 03:12 PM
RE: Question about 118b - by morzh - 09-10-2014, 03:21 PM
RE: Question about 118b - by Mondial - 09-10-2014, 08:12 PM
RE: Question about 118b - by Arran - 09-11-2014, 03:54 AM
RE: Question about 118b - by Ron Ramirez - 09-11-2014, 08:08 AM
RE: Question about 118b - by Mondial - 09-11-2014, 09:37 AM
There are currently 10416 online users. [Complete List]
» 4 Member(s) | 10412 Guest(s)
AvatarAvatarAvatarAvatar
